My Boxford is an ex school model I was given about 20 years ago. I got it running, just, back then but then a move of workshop space left it in a corner gathering dust until last week.
Condition is not great but I don't intend a restoration just to get it working and make it safe.
So a couple of questions :-
1. How to change speeds, I guess I just move the belt by hand as there is no mechanism but any trick to it?
2. It has no spindle lock so how do I remove the chuck (I have read that using the back gears to lock the spindle is not a great idea)?
FWIW it all seems to work, all gears available, lead screw works, and it's remarkably quiet. The motor is a salvaged ¼ HP single phase ex-washing machine unit with rudimentary wiring, that will be the first bit to be tidied up. I know it's underpowered but I will change it later when I know everything works properly. The motor pulleys are oversize I think as spindle speeds are +25% which is not ideal. I'm electrically competent but can anybody suggest the simplest cheapest way to wire it up (tested it with a plug in RCCD to switch on and off)?
Edited By Sam Spoons on 04/04/2020 13:41:42
