Bob, I find the best segmented belt is the Fenner "Power Twist", it has no metal parts, the links have an arrow head at one end, and a triangular hole at the other. My lathe has 1.5 hp, and B section belts, the primary belt (from motor to counter shaft) is Power Twist, it's been there since 1990. I'v been using NU-T-Loc belt on the spindle, it only lasted from 2009, although it is easier to work with than the old Brammer belt with the round head rivits.
Mike, thanks for the tip about assembling the belt inside out.
Ian S C
Edited By Ian S C on 18/11/2014 11:13:10
