Boxford 8″shaper
Boxford 8″shaper
Home Forums Manual machine tools Boxford 8″shaper
Viewing 12 posts - 26 through 37 (of 37 total)
  • #629945
    RobCox
      @robcox
      One more comment on the inaccuracy of that animation. Notice how the chips fall into a single pile, rather than spitting all over the workshop!
      Ady1
        @ady1
        Yet another subtle geometric titbit is in that animation
        The fixed link from the top of the powered pendulum means you can use a hole and pin in the ram
        If the pendulum attaches directly to the ram, like in most compact shapers, you need a vertical slot instead of a hole because it describes a tiny arc at the tip (So the pin goes up and down)
        #629962
        Les Riley
          @lesriley75593
          My Elliot 10M shaper has an obvious direction arrow on the vee belt drive guard.
          #629966
          Peter Simpson 3
            @petersimpson3
            Looking at the motor pulley which direction is "normal" CW or CCW ? I will have a look to see if my Boxford has a direction arrow.
            #629967
            noel shelley
              @noelshelley55608
              I have an Elliot 10m and yes it must run the right way and the geometry does give a slow out, faster return. Also the original motor was a 6pole, giving about 960 rpm, not the more common 4 pole at 1430rpm. Noel.
              Edited By noel shelley on 18/01/2023 10:28:27
              #629973
              Ady1
                @ady1
                The forward power cutting stroke is when the drive pin is at the top of the circle because you get more torque when the pin is further away from the anchor/hinge point of the pendulum
                It's like opening a door, the further from the hinge you go, the easier it is to move the door
                Mr whitworth was a very smart cookie
                #629995
                peak4
                  @peak4
                  Posted by Peter Simpson 3 on 18/01/2023 10:24:39:
                  From the owners manual Installation page
                  "The motor and countershaft pulley should rotate in a clockwise direction when viewed through the drive compartment door. Machines for single phase electric supply are correctly wired before despatch.
                  Machines for 3 phase supply can be reversed if necessary by changing over any two leads from the supply
                  Here is a useful page for info on shapers generally
                  https://www.circuitousroot.com/artifice/machine-shop/shaper/literature/index.html
                  Bill
                  #630001
                  Peter Simpson 3
                    @petersimpson3
                    Brilliant info. My shaper has been going the wrong way since I purchased it 6 years ago. I will swap a couple of motor connections and get it going the right way.
                    #630147
                    Kiwi Bloke
                      @kiwibloke62605
                      Is it also worth pointing out that the auto table feed should feed on the ram's return stroke, and go 'Click, click, etc' on the cutting stroke? I've seen them wrongly set…
                      It's worth checking to see that the ratchet on the table feed doesn't also drag the feed screw backwards, so it oscillates, rather than feeding steadily. IIRC there's no built-in provision for adding some friction to the feedscrew's rotation, to prevent this from happening.
                      #630154
                      Robin
                        @robin
                        Did you get/are you fixing the vertical feed? I had to tighten up the horizontal before I dared turn it on dont know
                        I think I want to fit a fridge-style, internal light that comes on when I open the octagonal door. I't a bit gloomy in there.
                        Robin
                        #630172
                        peak4
                          @peak4
                          Posted by Kiwi Bloke on 19/01/2023 10:18:34:
                          Yes, as I recall, after fitting the vertical drive gear, I had that problem.
                          I'm in the house at the moment, but I think I added either a fibre washer, or an O ring, behind the micrometer dial to add some friction to the shaft leadscrew assembly.
                          Bill
                          #630210
                          John Olsen
                            @johnolsen79199
                            Most shapers will not feed properly just after you reverse the ratchet. The quick and dirty solution is just to move the handle a bit in the new direction to take up the backlash. Once that is done they drive OK, at least all my three shapers do.
