Hi Matt,
Read your post re Boxford 240 tcl lathe, it looks as though your ahead of me, mine being a non-runner at present.
I am in the middle of a full conversion of a 240 tcl as follows. Changing all electrics including front panel have drawn up a new one have yet to make it fitted with many function buttons using the Mach3 OEM codes.
My biggest worry is getting the 8 station tool changer working having difficulty getting a macro and instructions how to set that up.
My conversion is :- spindle is 1.5kw 3 phase motor controlled by inverter, Forward-reverse-stop-start-jog and variable speed. I am not going for Mach3 software control at present to be done later when i have the 240 running.
Spindle control for screw cutting by index pulse card. I have changed the transformer, stepper drivers, fitting a spindle rev counter to the front panel.
I am about half way through building the circuit board and wiring up ready to fit back in the machine.
Can i ask if you have any information on setting up the tool changer i would be grateful.
I have converted a Boxford 190 mill with the aid of my husband, which is great.
Best wishes,
Cheryl
Edited By John Stevenson on 26/04/2015 01:33:47
