Box pan folder recommendations
Home Forums Workshop Tools and Tooling Box pan folder recommendations
  • #641719
    Brian Abbott
      @brianabbott67793
      Hello.
      I always struggle with bending material, always have.
      I end up making formers for everything.
      Does anyone have any experience with box pan folders?
      Looking for something 12" long, maybe like the one Warco sells
      Thanks
      Brian Abbott
        @brianabbott67793
        #641722
        Anonymous
          I've got one, made by Edwards, but 48" by 14g. They are useful, but require some forethought as to the sequence of bends.
          A press brake would be ideal for bending, but 4ft ones are extremely rare.
          #641724
          duncan webster 1
            @duncanwebster1
            Test lab I worked at once had a flypress with a long vee block sat on the base and assorted length bits which could be clamped in a holder on the ram. Worked a treat, and was very good at pushing bearings in/out as well.
            #641729
            Nicholas Farr
              @nicholasfarr14254
              Hi, like Andrew Johnston, I've only ever used the Edwards type industrial ones, but as Duncan Webster has said, a long Vee block can be used, and that is exactly what I made which is 500mm long. Different length blades can be used for box folding, Sheet metal block & blade I've only made one blade so far for this, but I can use my Vice-Brake blade that Waco sell, Vice-Brake which I made a block to hold it in my flypress Folding Tools which were adapted for folding small parts.
              These tools can also be adapted for use on a hydraulic garage type press.
              Regards Nick.
              Edited By Nicholas Farr on 18/04/2023 07:32:55
              #641731
              Baz
                @baz89810
                Gabro do two sizes of box pan folder, a two foot and a three foot version, the smaller is ideal for a model engineers workshop.
                #641744
                Colin Heseltine
                  @colinheseltine48622
                  I have the Gabro 600mm folder. It is great piece of kit Can also do large radius bends if use piece of tube for the top clamp bar.
                  colin
                  #641771
                  Martin Johnson 1
                    @martinjohnson1
                    I think Vince Gingery did a book on making a DIY version of the Gabro. Have a look at Camden's book list.
                    Martin
