I have some HSS boring tools that are somewhat like D-bits.
Setting them is quite critical, as you need to angle them to get some top rake, whilst ensuring that the round undersurface doesn’t rub. When the hole is near to the diameter of the cutter, it’s best to arrange it with no top rake at all. You can add more as the hole opens out a bit, if required.
the knack is to look very closely at the tool tip when it is stationary and touching the work. Check for point contact at the cutting edge, and no rubbing.
It is a bit trial and error, but as you normally start with hole a lot smaller than finished size, you have plenty to practice on
The boring bit is opening the hole up a few thou at a time!
