Boring table
Boring table
Home Forums Manual machine tools Boring table
  • #601981
    Alan Jackson
      @alanjackson47790
      I have added tee slots to my Chipmaster cross slide this enables many operations like this
      Alan
      Edited By Alan Jackson on 16/06/2022 12:01:34
      Alan Jackson
        @alanjackson47790
        Tee slotted cross slide
        #601991
        Hopper
          @hopper
          Posted by Alan Jackson on 16/06/2022 12:01:03:
          Alan
          A very handy mod. Brings it up to the standard of my ML7. laughlaugh
          Adding a vertical slide opens up all sorts of new possibilities too.
          #602025
          ega
            @ega
            Alan Jackson:
            Could you have carried out the operation on the Stepperhead?
            From the video it looks as though you have made a new cross slide for the Chipmaster?
            Edited By ega on 16/06/2022 17:26:20
            #602105
            Alan Jackson
              @alanjackson47790
              photo 20 modified vertical slide.jpgpict0013.jpgpict0008.jpgHi Hopper and vga,
              Yes I do have a vertical slide for this cross slide. I could have carried out this operation on my Stepperhead lathe but the Chipmaster is a much bigger and more rigid lathe and even on this I could only make about .020" cuts without chattering etc. I modified the original cross sliide by adding 0.500" steel strips bolted from underside.pict0004.jpgphoto 21 vertical slide mounted.jpg
              Edited By Alan Jackson on 17/06/2022 10:26:01
              #602110
              ega
                @ega
                Thanks for explaining.
                That vee on the vertical slide table looks very handy.
                #602115
                Hopper
                  @hopper
                  Nice. I like that V slot too. Handy for diameters too small to rest on the T slot.
                  I find the Myford swivelling vertical slide annoyingly flexible , which does limit depth of cut. But the fixed vertical slide is a much more rigid beast and much to be preferred for most jobs.
                  Edited By Hopper on 17/06/2022 12:05:49
