Might I disagree please – and I too have a collection of solid HSS boring tools all ground up on a Quorn (just so the angles are right)
An indexable carbide tip in a tool is always set at the optimum angle, and in many cases the tool is drilled for coolant.
Having set all at centre height, you can rough with one part of the tip, and then spin the tip round and bring a nice new sharp edge into play for the final cuts, with no loss of centre height, and in all practical senses with no loss of position. AND with the right nose radius (which is a PITA to apply on a tool and cutter grinder and almost impossible to do by hand), you know you’ll get a good or even outstanding finish, in some cases nearly comparable with grinding.
For my money, the indexable boring bar fitted with a decent grade of tip, is a great deal more convenient than HSS bar, and produces just as good a result.
There is probably not a lot in it in terms of cost either, because these days decent HSS from people like Eclipse, Cleveland Sandvik etc is very expensive.
(My definition of a good result – diameter +/- .0002, and a nice shiny finish)
Having said all that, I will accept that there are times when only a special tool will do, and then it has to be HSS, but for the general run of things indexable carbide takes a lot of beating
