HI,
Sorry for late reply, as is probably the case with most of the forum members I have been cursed by being a "practical man" so always other things to do, i.e. rcd unit tripping, bathroom to refurb, help friends (?) as in do you know anything about ? well the default answer should be "no idea about anything to do with that" but you tend to say yes don't you ?
Old mart, the 16mm boring bar is a decent option for me as I do odds and sods on the lathe for myself and could help others with the same type of work plus there are not any easy alternatives for bigger carbs, they are a flat slide carb with power jets (internal unusually) and are mounted at around 45 degress so the float chambers have to suit, the only bigger bore alternatives need more modification to fit them than is required to bore from 26 to 28mm, the reason for boring the carbs is engine upgrades, two stroke porting and capacity increase with better expansion chambers means that although the standard carbs will work the bigger bore size with correct jetting helps with a substantial power increase through the rev range,
Oily rag, Martin,
They are not pumper carbs but do have a "power jet" which unusually is internal to the carb, you are probably familiar with most power jet type carbs that have an external mounting on the intake side of the carb with a jet fed from the float chamber via an external tube,
re bell mouth changes, they are pretty good on the intake side with a very nice looking profile to the bell mouth shape, I still haven't had chance to get back on with the good jobs (bike engineering in my garage) due to other more mundane stuff to get out of the way, I could take a picture or two when I have a bit more time.
I agree that the youtube video of the diy boring bar is not a great example, I am of limited experience with turning, boring, milling etc but I do have a motto that there are only two ways to do a job, a right way and a wrong way, well that does not look the right way to me, the execution is poor, I cringed when the drilll bit was clearly off centre when drilling through the bar and as someone else said even the filing of the hole from round to square was a bit iffy, he would not have got his O level (GCE not gcse) metalwork at the school I went to, however the idea seems sound so I might have a go at making my own, it does look like the finished bar would work well for my purpose,
One of the replies mentioned being careful about getting the carbs mounted perfect for the obvious reasons of not getting the machining perfectly concentric, well the good news for me is that the carbs will mount directly into the three jaw chuck on the intake spigot so unless I have a meltdown (imminent) then it should not be a problem,
I will measure up my tool post asap and see if I can get a 20mm bar into it to clamp correctly, if not I will most likely go ahead with a 16mm bar and prcoeed with great care, the carbs that I am boring out are a spare set but as they vary between £200 and £600 a second hand set then I don't want to damage even the spare set,
Thanks for all the input, much appreciated,
Regards Jeff
Edited By Jeff Austin 1 on 17/01/2021 08:24:04
Edited By JasonB on 17/01/2021 12:15:47
