Boring a hole in brass
Home Forums Beginners questions Boring a hole in brass
  • #336698
    BOB BLACKSHAW 1
      @bobblackshaw1
      Is it best to bore a hole first then drill the inlet holes after, this how I usually do this but I have problems with burrs. Or if I drill all the inlet holes first will I still get a neat hole from the boring tool as it touches the inlet holes in the bore. Thanks for any replies
      BOB BLACKSHAW 1
        @bobblackshaw1
        #336701
        Russell Eberhardt
          @russelleberhardt48058
          If you drill the inlet holes first you might get some slight ripples in the bored surface near the holes, depending on the rigidity of the boring tool. You can always remove them afterwards with a hone.
          Russell
          #336717
          bricky
            @bricky
            I have bored a hole with a cross hole through and the deflection when boreing over this hole made the bore slightly tapered.I would bore first and cross drill and use either a reamer to debur or an internal scraper.
            Frank
            Edited By bricky on 14/01/2018 17:00:07
            #336721
              Bore the hole and make a close-fitting plug of similar material; then drill the inlet holes.
              Unless the brass is particularly nasty stuff [in which case the plug might get rivetted-in surprise] the plug should slide out, leaving a clean result.
