There is a slightly different way to look at it, and thats the function of the boat itself.
If you want an all out racing boat, it will be a very different engine design, and therefore selection of criteria such as bore vs stroke, and if you were making a tug to be used in bollard pulls, where torque would be major function, or if you want a nice simple, easy to live with boat, where you would choose a simple design.
If you wanted a high speed racer, general thinking is that the line to follow is an over-square stroke, multiple cylinders and a uniflow exhaust. The engine is driven purely by initial input pressure, which can be 1000’s of PSI, and there is essentially zero benefit taken from the expansion properties of steam, as the engine is turning too fast. This might give an engine turning at 5,000 – 10,000 RPM, which would usually be coupled directly to a small racing designed prop.
For say a tug, where you look for maximum torque, then long stroked compound engines would be where you would start, giant propellors, and going to lengths to eek out every scrap of energy from the steam, such as the condensers discussed above.
Like anything else in this lovely hobby, the “right” answer depends on the question you started with.
One other thing I would say is that Jens make a comment about needing a “larger” boiler in his first post.
I would say that what is actually needed is a more efficient boiler, rather than a larger one. One of the big benefits of steam powered toy boats, over steam powered toy trains ( apart from the significantly lower drain on the wallet ! ) is that you get an unlimited supply of free water, so the question of boiler size comes less down to “how long will it run for before I have to fill her up” and turns into “How can I make enough water turn to steam”
You can make very small boilers which produce vast amounts of steam, as long as the water is available to actually make it in the first place.
