Boley & Leinen
Boley & Leinen
Home Forums Workshop Tools and Tooling Boley & Leinen
  • #383072
    Adam Phillips
      @adamphillips50363
      Hello all
      I have just started to rebuild the head stock of my new old Ebay Boley & Leinen model 83 lathe. The bearings are shot and grumbling . They appear to be oil lubricated as there is a wicking system inside the head casting. So my questions are should I fit sealed bearings or the unshielded type as original. more important perhaps is what type of oil to use.
      thanks in advance
      Adam Phillips
        @adamphillips50363
        Spindel oil
        #383076
          It's probably available in bulk, at a better price, but this looks a reasonably safe bet: **LINK**
          http://www.small-lathes.co.uk/Lathe-Oil-–-ISO-15-–-500-ml-Bottle-%5BStk.-No.-WLO15500%5D/422.htm
          As for the bearings; I would go for the original style in the best available quality.
          … Given its pedigree, one would hope that the spindle was appropriately designed and engineered.
          Adam Phillips
            @adamphillips50363
            Thank you Michael. The oil and bearings are on the way
            #383095
            duncan webster 1
              @duncanwebster1
              Bit of a mark up there I think see
              Adam Phillips
                @adamphillips50363
                Burned again.I know where to go next time. Thanks Duncan
                #383188
                  Posted by Michael Gilligan on 30/11/2018 15:53:19:
                  angel
