Boilers
Boilers
Home Forums Materials Boilers
  • This topic has 11 replies, 9 voices, and was last updated 8 July 2018 at 09:13 by Russell Eberhardt.
  • #346025
    John Harris 4
      @johnharris4
      Any views on stainless steel boilers. Has been suggested by a fried, a coded welder, for a 5 in Shay? Was going to go down the copper route but this an attractive alternative as the intention was to leave the model bright metal.
      John Harris 4
        @johnharris4
        Stainless Steel Boilers
        #346073
        Brian H
          @brianh50089
          The first boiler I made, for a 5" Terrier was in aerospace certified 316 Stainless Steel and was welded by an aerospace certified welder.
          It could not be accepted as there was no class for it, ( I'm going back many years). So I learn't my lesson and consulted the club boiler inspector before building another but things may be different now.
          #346076
            You certainly won't be able to have it tested by a club inspector as the scheme only covers copper and steel. Speak with a professional boiler inspector and insurance company to see what the costs will be for design approval, initial and yearly testing and insurance.
            #346079
            Speedy Builder5
              @speedybuilder5
              I made one (Aerospace quality 316 ss in 1965 ) for a 5" Firefly, but never proceeded to insurance test stage as by then it was discovered that over a period of time (apparently) you would possibly experience 'brittle fracture' along the waterline between water and steam. I believe that Australia has a different 'take' on the subject. it was a bit of a sweat belting hell out of the backhead to form the 1/2" flange, firebox also but I did it with jab rock formers and a club hammer, cold. I did pressure test cold to 200psi and all was Ok. tube Joints were silver soldered, the backhead , barrel etc were argon welded by a coded welder.
              BobH
              #346082
              duncan webster 1
                @duncanwebster1
                Austenitic stainless and (very) hot water are not a good combination, you can get pitting and stress corrosion cracking. I think there are grades of SS that would be OK but whether you can get them in small quantities/thin sheets is anyone's guess. As others have said, you're not likely to get a ticket from a club inspector, and to do it via an insurance comany as a one off would cost as much as a copper boiler. In any case, you want some cladding to keep the heat in, so make that out of SS and no-one will know.
                #346084
                Thor 🇳🇴
                  @thor
                  Hi John,
                  As mentioned by Bob other countries (Australia) may accept stainless steel boilers. This one is in "Duplex" steel, not 316.
                  Thor
                  #346085
                    Plenty of stainless ones across Europe.
                    #346096
                      duncan webster 1
                        @duncanwebster1
                        Posted by Neil Wyatt on 14/03/2018 18:10:55:
                        Here are a few recipes
                        en.wikipedia.org/wiki/Materials_for_ressure_vessels
                        I don't think the OP was considering a nuclear fired boiler.
                        #361134
                        Will Taylor 1
                          @willtaylor1
                          Hi all, what’s the feeling about having a brazed joint on the boiler barrel. The joint is a butt joint and it’s also rivetted.
                          #361167
                          Russell Eberhardt
                            @russelleberhardt48058
                            Copper boiler? Silver soldering = brazing with silver alloy, that's normal.
                            Russell
                          Home Forums Materials Topics
