The subject of fittings does seem to be a grey area. Appendix B of the code says:
“In addition to the normal inspection for leaks, adequate joints, correct thickness of materials and the absence of any appreciable distortion/bulging to any surfaces, inspectors may wish to consider the following points: “
Note it says may wish to, not shall or should !
The criteria in appendix B for fiitings seems to be the same for new and previously tested boilers i.e.
‘All screw operated valves should be checked to ensure that they cannot be screwed out whilst under pressure’
My interpretation of that is that a boiler with valve spindles that can be unscrewed should be failed whether it is new or old but the opening paragraph to appendix B suggests that the inspector can choose to ignore this?
Definitely something that needs to be clarified!
Edited By John Baguley on 14/09/2009 00:42:40
