I'm building a 3" Burrell Traction Engine and have a commercial copper boiler. It has come time to fit the cylinder to the boiler. The drawings call for 24 2BA copper studs, but I can't workout if the tapped holes in the boiler for the studs should be through holes, or blind.
The boiler is 1/8", with a second 1/8" pad silver soldered onto the inside where the cylinder sits (so there's 1/4" of copper to bolt to). The studs are radial (so need to be inserted after placing the cylinder and can't be soldered in place). A through hole would give 7-8 threads. However, if I go for a blind hole, I'm not sure I'd get more than 3 threads (and I'd be worried about ensuring the holes are exactly the right depth). What would be the normal practice?
Many thanks in advance,
Martin
