Boiler stays
Boiler stays
Home Forums Beginners questions Boiler stays
  • This topic has 6 replies, 4 voices, and was last updated 1 May 2010 at 17:26 by Speedy Builder5.
  • #51283
    Speedy Builder5
      @speedybuilder5
      When rivets are used, are they just silver soldered in or does the small end have to be set before silver soldering.
      Why are threaded stays used instead of rivets, or studding used ?
      Speedy Builder5
        @speedybuilder5
        Rivets, studding or screwed stays
        #51285
        macmarch
          @macmarch
          You are using the rivets and stays to prevent the flat sections of the boiler from bowing and  blowing out.  So, yes set the rivets. Do not, however, rely on rivets to hold against pressure to compensate for bad fiiting of the plates.  Rivets should be used to hold while siver soldering.  There is no gap between the plates so silver solder cannot flow bvetween them.  The idea of using screwed stays is so that there is no  possibility of them popping out. They also hold the plates rigid to each other.
          Ray
          #51286
            You should just be able to poke the rivits through the plates from inside the firebox, silversolder them and trim off any excess. Any attempt to set then will just push the firebox and wrapper together. You can bend them slightly so they don’t fall out.
            Jason
            Edited By JasonB on 30/04/2010 20:15:03
            #51296
            macmarch
              @macmarch
              Jason, That’s what I meant to say. Don’t set a rivet when there is a gap;  only to hold parts together for SS.
              Ray
              Edited By macmarch on 01/05/2010 09:37:00
              #51303
              KWIL
                @kwil
                Do not forget to lightly countersink the plate around the rivet stem to allow a ring of SS to form.
                #51313
                Speedy Builder5
                  @speedybuilder5
                  Thanks for all that info – makes it a bit clearer – Bob
