Boiler life
Boiler life
Home Forums Locomotives Boiler life
  • #938
    Ivan Prince
      @ivanprince58081
      Ivan Prince
        @ivanprince58081
        I am looking at buying a second hand loco and have a question about boilers
        I know that the boiler will require a test certificate but what is a reasonable life expectancy   of a copper boiler
        Ivan
        #49774
        KWIL
          @kwil
          I recently saw a club loco boiler which had been in use for 30 years. Not a pretty sight however, but it had been working and was due for replacement. It all depends on the standard of silver soldering, good staying and workmanship, adequate copper thickness with sufficient fillets etc to withstand the attacks by combustion products.
          #50413
          gardener69
            @gardener69
            Copper boilers maintained right should last a lifetime.  In Australia they are re-examined and certified every three years.  There are not many that fail.  If buying 2nd hand buy on the basis of the boiler passsing its test certificate and ask around at the club where it has been running, other members will know the history.
            Gardener69
          Home Forums Locomotives Topics
