Boiler Inspection Options
Home Forums Traction engines Boiler Inspection Options
  • #2909
    Puffafish
      @puffafish
      Puffafish
        @puffafish
        Greetings all,
        Having a poke around the miniature steam re-sellers, they comment on the current boiler certification, as you would expect. When I've been having a butchers, I've noticed that most say either "current boiler certificate" or "we'll do a boiler inspection before you take it away". Which is nice of them. However, when looking at the smaller (say 2" scale or so) they seem to say "talk to us about options".
        What are these "options" surly you either get it inspected and signed off (and so can get the all expensive insurance) or you don't get it inspected (and either use it as a static model or just drive it in private).
        Is there something else to it when looking at the smaller engines? Or is the "contact us for options" is because the sign off is expensive for a small machine which could spend all it's life as a model rather than a living breathing engine?
        #400151
        Paul Kemp
          @paulkemp46892
          Interesting question. Not noticed that but then not usually trawling sale sites for models unsurprising maybe.
          i would hazard a guess though that it is because commercial sellers do their certification on the commercial basis and commercial certification cannot be mixed with the 'club scheme'. For example if you have a 10 year hydraulic from a commercial inspection you can't get your annual steam test and cold exam done by a club inspector, they will need to do their own hydraulic also. So it really depends which regime the purchaser intends to follow after purchase, if he wants to do the continuing tests through his club it makes sense to take the boiler untested and get the club to do from the outset of ownership. If continuing on the commercial basis then you may as well take the certificate. I am not sure who pays though because there is a cost involved ie if the seller tacks the cost of certification on to the deal it will save the buyer money, if the seller absorbs the cost then by not doing the test he increases profit!
          Either way if taking a model untested and even if not, make sure it comes with previous boiler history as if you take your new toy to a club with no previous evidence of boiler manufacture standards and previous tests they are well within their right to refuse a certificate!
          One last point is I have seen boiler certificates issued by sellers / in conjunction with the sale that do not comply with either standard commercial (10 year hydraulic) or club (2 or 4 year hydraulic) periods! One boiler in particular came with a set of certificates for six months and the details on the certificate did not properly match the boiler! Made me wonder why the tester was not confident to issue a proper full term certificate! A commercial test certificate should be backed up with an inspection report, particularly on a steel boiler with records of ultrasound readings and extent of inspection carried out. So as always it's a case of buyer beware and be sure what you are getting!
          Paul.
          #400163
            It is quite possible that some people who buy the smaller engines will never steam them in public or not even steam them preferring to have them as display models that get the odd puff of air for pleasure. It may be that the seller would have to do some work on a small model let alone have it tested so they may give the option of a lower price to take it uncertified or pay more to have one that is is working order and ready to run.
            There will also be engines that need a lot of refurbishment and that will be reflected in the price and the buyer may be willing to take a risk and pay a low price with an unknown boiler.
            J
          Home Forums Traction engines Topics
