Boiler Feed Pump Missing
Home Forums Traction engines Boiler Feed Pump Missing
  • #2793
    Lee Marsh
      @leemarsh86275
      2″ Scale Clayton & Shuttleworth TE
      Lee Marsh
        @leemarsh86275
        I have acquired a 2 scale Clayton and Shuttleworth Traction Engine, trouble is the crank driven feed pump is missing. The eccentric and connecting rod remains. Does anybody know where I could obtain a suitable casting as I have trawled the net all the usual suspects and found nothing.
        The engine steams and runs great and I believe is a rare model any assistance would be appreciated.
        Regards Lee
        #153509
          Unless somebody has one lurking under a dusty bench I don't hold out much luck of you finding a casting. In which case you will have to fabricate something from bronze and brass, several other 2" engines use this method rather than a casting.
          Gloucester Steam do a 4" version and you may be able to half the drawings from that to get the general layout
          J
          #153511
          Lee Marsh
            @leemarsh86275
            J,
            Thanks for the reply, actually I have the 4" scale drawings forms GS and was toying with the idea of making one. Thought I would try my luck first just Incase I missed a supplier.
          Home Forums Traction engines Topics
