Wow! That a lot to take in, thanks to all.
This is where I am at::
I have discovered (from Stuart) that the engine should be mounted horizontally to enable the sump to retain oil for splash lubrication. Doing this has moved it forward into the space where the paraffin burner tank was located.
As I remember this burner was an all or nothing device, which was great if you required flat out power, but I want more control over the flame with a requirement for more sedate running.
Work is progressing on the feed pump drive which is going to use a worm on the crank (36:1) driving a 1/4 in bore pump with the stroke to be determined.
Probably over the Christmas period I shall fire it up in my test facility (bath!) flame is going to be supplied by my range of Seivert burners and I hope to establish the maximum size (kW) of burner required for full power to maintain boiler pressure.
While this is going on I shall be counting pump strokes from the hand pump (3/8 in bore) mounted in the hull – hopefully I can calculate the water consumption!
I think prior to this it might be prudent to carry out a hydraulic test of the boiler.
I am not sure if this is to an acknowledged design, it appears well made from 3/32 seamless copper both for the outer and inner shell with diagonal cross tubes all siver soldered together.
The Bassette Lowke gauge fitted reads full scale 60 psi? which would suggest a working pressure of 40? (seems low) any thoughts on test pressure?
I am trying to basically finish off the boat to a usable level and am trying to keep things simple!
