Hi Neil ,
Can't locate relevant ME but here's some of it from memory .
They tested at least three boilers .
Boiler no 1 was a specially made pot boiler with end discs soft soldered in .
Boiler no2 was exact same design as no 1 but silver soldered .
Boiler no 3 was a 'proper' model firetube boiler – possibly from a Chub or similar design and described as poorly made .
Modus operandi was to fill boiler with water , connect a high reading pressure gauge and to fire up with propane torch . Some safety precautions taken by having personal being well back from test point and improvise bunkering .
Boiler no 1 failed destructively in that the ends blew out at pressure – probably around 150 psi .
Boiler no2 never actually failed destructively . In several tests pressure was raised to over 500 psi with no problem . Ultimately the boiler was just fired continuously until it started leaking – probably due to pinholes blowing through . No record of final pressure reached but it must have been enormous and boiler described as having become balloon shaped .
Boiler no 3 never failed destructively either . At quite modest pressure leakage prevented pressure getting any higher .
Failure of boiler no 1 was apparently quite violent and end disc flew some distance before impacting on a tree .
There is much more information in the actual articles so I hope someone else can supply you with copies .
Regards ,
Michael Williams .
Edited By MICHAEL WILLIAMS on 07/10/2012 21:16:39
