Noel, I am currently agnostic on fuel, though was thinking a meths burner with multiple heads. The boiler was going to be vertical because that way I can direct the heat a bit better.
For feed water I was going to put in a crankshaft driven pump, and a hand pump. Might if that all goes OK put in an injector just to see if I can make one work.
In practice I expect it will actually run at a much lower pressure. The main parts of the exercise are:
1. Work out designing and building a model boiler for bigger projects.
2. Work out designing and building an engine plant, also for bigger projects.
I was planning on making it running Joy valve gear a bit like Muncaster's engine.
