Well, thanks, there are 3 different ideas, all of them I understand. The iron plug idea for smaller threads would allow the bush to be supported in a jig to ensure that it was "square" to the required axis but never heard it talked about and a heartache if a spot of silver solder made the plug stick in the thread.
As Jason said, the fine threads are at risk of burning but Fizzy who has made more boilers than most of us put together hasn't had a problem.
And David rightly is concerned that a unless the bush is tapped in the lathe, then there is a risk the face of the bush is not square to the thread.
Has anyone tried some sort of "fire clay" to put into the bush during soldering ??
