Bodmer’s Sliding Cylinder Engine
Home Forums Stationary engines Bodmer’s Sliding Cylinder Engine
  • #51692
    Dave R
      @daver15428
      I have just got the castings and drawings for the above, has anyone else tried this one?
      Dave R
        @daver15428
        #51695
          Not tried it but its a nice looking engine. If you don’t have the original build series articles they are reprinted in his book and worth having.
          If its of any help this homepage of a german builder has a lot of pictures of constrution if you click the “zum bauburicht” link at the bottom of this page, the other link takes you to photos of the finished engine and a video of it running
          Jason
          #51755
          Dave R
            @daver15428
            thanks very much, there is nothing like some pictures to follow, the words are less important. Thanks for the reply
              Just put the web page into a translator like Babblefish, it comes out quite well but a few of the technical terms can be a bit amusing
              Jason
              #89989
              tony bastick
                @tonybastick78554
                Hi,iv just started the restoration and overhall on one of these engines, does anybody know how to set the valve timing? Tony
                #90006
                NJH
                  @njh
                  Hi Tony
                  Anthony Mount gives details of the valve settings in his book "Historic Engines Worth Modelling : Volume 2 " – click here for info. He usually exhibits at the Bristol Exhibition in August and I'm sure he would be willing to advise you.
                  Dave I too am attracted to this engine although the practicallity of a design which moves a heavy cylinder rather than a realtively light piston is questionable! Anyway I must first finish some of my outstanding ( or maybe that should be longstanding!! ) projects!
                  The finish achieved on the example in Jason's link is quite exceptional.
                  Norman
                  #90008
                  Ian S C
                    @iansc
                    I wonder if the idea of moving the cylinder was to use gravity to supply the power on the down stroke? Ian S C
                    #90010
                    NJH
                      @njh
                      Hi Ian
                      I understand that the steam is fed down the ( hollow) cenral column and directed by a piston valve in the cylinder to either the top chamber or bottom chamber of the cylinder which has a fixed "piston" at its centre. The exhaust is similarly directed to the bottom of the central column.
                      Norman
                    Home Forums Stationary engines Topics
