Posted by Pete Rimmer on 25/02/2023 16:55:16:
You're not getting a timesert onto that there's not enough meat. If it were mine I would make a hardened drill bushing and put a 6mm slot drill down it until all of the bolt was drilled out, then I would simply use a longer bolt to pick up the remaining thread.
+1 on this. A slot drill with a hardened guide bush is far less likely to wander than even a stub drill. You are trying to drill out an offset hole in two different materials, one hard and one soft, that's a big ask for a drill bit.
I can't really tell from the photo but you might be able to make your own oversize threaded insert and drill and tap to suit after removing the bolt if there is not enough thread to use deeper in the original bolt hole.
Or alternatively, if the existing helicoil is securely in place, is there any reason you can't use it as is? If it is not quite straight, you might have to enlarge the hole in the ring that it retains and maybe even machine a tapered washer to suit? A bit bodgey for sure, but may be an alternative if you absolutely don't have enough "meat" there for inserts etc and the threaded hole has not extra threads deeper inside. Better to "bodge" than destroy an expensive wheel if there is not enough metal there to play around with, and it does look very thin there. Not familiar with Guzzi wheels but the bolts are not transmitting drive, just holding the retaining ring for the cush rubbers, are they not?
Edited By Hopper on 26/02/2023 02:55:40
