I think the main obvious benefit is ram travel, you might need to reset the table height on a hydraulic press half way through, obviously the size is also a factor but I think you'd need a very big hydraulic press to push a 14" broach through in one go.
Having put bearings in with both hydraulic and arbor presses, you get a very definite feeling when a bearing is properly seated with an arbor press, it's nice knowing it's both fully seated and you're not continuing pressure after it is seated.
with a hydraulic press you've got more factors to avoid damage, my hydraulic press does not have a gauge what resolution are they? the resolution would need to be high enough that small components could avoid damage, by the time the gauge is showing that excess pressure is being applied the damage could potentially already be done.
For bearing installation an arbor press is much better option in my opinion, broaching also, there's a place for both types of press, I just prefer these old mechanical ones, I find they are much quicker to use, just spin the daisy wheel around to a suitable size opening and away you go.
Marlco still make the bridge type arbor press for broaching, the bigger size is around £4500 with VAT, so I guess price is subjective depending on how much you need it or want it, even a hobby import arbor press big enough for broaching is probably gonna set you back the best part of £400
Marlco press
Edited By Pete. on 11/12/2021 00:53:35
