Slight aside to this but I have noticed a change in hot rolled bar over the last couple of years.
Normally hot rolled is a bitch to machine, gummy, tears and not great. Recently i had to price out some location pins in 90mm round.
As you would expect the material was pricey and the job they were doing wasn’t critical.
I found out that for a 10′ bar of 90mm bright drawn it was £140, hot rolled or just black came in 7 metre lengths, nearly 23′ and was £166
Given the OD had to be machined I went for the black and ordered it cut into two lengths for handling. As it turned out it was delivered whole which caused some joy on the day, I can recommend Aldi’s 9″ angle grinder <g>
When machining this it turned out to machine very well, more like an EN8 steel with a very good surface finish.
Recently I have ordered smaller sizes and still getting good results, the cut off point seems to be around the 3/4″ / 20mm mark, under this it’s rubbish again, possibly because in the smaller sizes it cools quicker.
Anyway if you need larger diameters don’t be put off by black hot rolled.
John S.
