Blow torch
Blow torch
Home Forums Workshop Tools and Tooling Blow torch
  • #618898
    hawk gripen
      @hawkgripen92641
      img_20221025_094613.jpgCan some one please identify the following tool / burner and how it works. img_20221025_094552.jpg
      hawk gripen
        @hawkgripen92641
        ELTO
        #618899
        peak4
          @peak4
          I'm not 100%, but I think it's an electric de-soldering tool.
          If so, the pipe connector by the handle should go to a vacuum pump, like a car tyre foot pump, but in reverse.
          I have something similar but made by Philips, though mine has a separate reservoir for capturing the recovered solder droplets.
          Bill
          #618912
          Cyril Bonnett
            @cyrilbonnett24790
            ELTO Trademark Information
            Trademark by ELTO S.p.A.
            Chemicals for use in electronic and electromechanical applications for engines, industrial machinery and electronic equipment and parts; chemicals and chemical preparations for use in the process of welding of metals; soldering fluxes
            Metal alloys for soldering and brazing; metal wires and rods for soldering and brazing
            Gas-operated soldering irons; gas-operated cutting blow pipes and gas-operated soldering blow pipes; electric arc welding machines; plasma arc welding machines; electric arc cutting machines; plasma arc cutting machines; compressors for machines; air brushes; and parts therefor
            Electric soldering irons; electric arc welders; welding electrodes; welding masks; apparatus for recharging commercial and industrial power sources, namely battery chargers; and parts therefor
            Heating apparatus, namely gas-operated heating torches and gas ovens; apparatus for the production and emission of hot air, namely gas heaters and regulators; cooking rings and fluid gas lamps
            Company ceased production 2004
