Depends where it is, if just on a cast surface that will be painted JBweld or car body filler. At the other extreme if it is in the cylinder wall drill it out and silver solder in some brass rod turned from the same material. Though small holes can also be cured with JBW
Hey Joe, depends where the hole is ? If it’s just for looks then filler, if a machined face then it depends how big. Fill with braze, drill, plug and silver solder or if really bad , recast ? Do you know why you have a blow hole ? Noel.
