I have a Blick clock which I have raised from the dead by dumping its synchronous motor and gearbox and fitting a stepper motor. It is the sort of thing which used to drive factory hooters, school bells etc. There is a big gear with 288 teeth, from which I want to drive a small pinion to trigger an hours chiming device. The OD of the gear is 7.375, so add 2 to the teeth and divide and I get 39.3 dp, or 0.65mm module. It is definately not 7.25" OD (40 dp) I can't believe either of these. The original design was American, so I'd suspect it should be dp. Any one got any better information? I daresay it will work with 40 dp, or I could make a lantern pinion with the odd dp, but it would be good to be sure I'm doing it right
