I was at the Midlands model engineering exhibition yesterday and bought the last Blackgates twin from there.
Having got it home, I am looking at the standard, thinking about the best way to machine it. It looks like they, in their machined kits, did it on the lathe presumably in a 4 jaw chuck.
Is that what people have done?
If so, was it the first operation or did you square the base first to take the casting taper off first?
Also, I presume that prior to putting it in the 4 jaw chuck you need to find the centre if the crank journal so as to drill and ream it to make sure the crank runs at 90 degrees to the port faces?
