Big HELLO from Dublin.
  • #447626
    Daithi
      @daithi
      Hi all,
      Thanks for the add. I just picked up my first lathe, Myford ml2 in poor shape. Looking forward to getting it running. Dave
      Daithi
        @daithi
        Myford ML2
        #447670
        Chris Evans 6
          @chrisevans6
          Welcome along Dave, what sort of things interest you ?
          #447671
          Steviegtr
            @steviegtr
            Welcome & hope you get the lathe up & running sweetly.
            Steve.
            #447699
            Brian H
              @brianh50089
              Hello and welcome Dave. Hopefully, someone on here may be able to help you with the ML2. Let us know how you get on.
              #447899
              Daithi
                @daithi
                #447903
                Daithi
                  @daithi
                  Thanks for the replies. I bought this lathe to make a few parts for an old BSA A10 I'm building from parts.
                  #448483
                    Welcome to the forum Dave, that should keep you busy for a bit
                    Search the forum for excellent advice on removing that sort of surface rust which won't have caused too much real metal loss.
                    Steviegtr
                      @steviegtr
                       My mate builds old BSA motorcycles. He is called Dars motorcycles. & I have had a few myself. Mine was a B33 clubmans that I rebuilt 1954. Also had a Bantam D14-4 with George tod head & 376 amel. I snapped the crank when over reving so fitted a Villiers 2T in the frame. . My friend has many of the BSA marque. Currently on the road he has a 1948 plunger, B31 converted to 33 spec. A B33 1954 in mint condition shortly coming up for sale. A A65 which is mint. A 500 BDB34 Goldstar in touring trim with the Standard gearing in with belt drive & Suzuki clutch. Starts at the 1st kick again in beautiful condition, with modified GP carb so has a slow running jet. Hope you get it up & running. A preferred model to the Triumph of which I had many. He sold his last Goldie to an American chap for £20,000 Regards.
                      Steve. P.S there were a few mods to that model of BSA that saved the crank from failing.
                      Edited By Steviegtr on 24/01/2020 02:36:04
                      #448617
                      larry phelan 1
                        @larryphelan1
                        Hi Dave,
                        I am in Enniscorthy, not too near to you ,but you are welcome to visit and maybe some of my gear, if it would help.
                        #448648
                        larry phelan 1
                          @larryphelan1
                          I meant to say,use my gear ! sloppy fingers !cheeky
                          #448714
                          Daithi
                            @daithi
                            Neil, Busy for sure. What a shame it would be to let this poor girl end up on the scrap heap.
                            Steviegtr. You know that there is no known cure for a Brit Bike addiction. I would love to hear more about your crankshaft mods, maybe in the motor area? I'm still finding my way (and getting side tracked) about the site!
                            Larry, Thank you for your kind offer. You know what a disadvantage we're at over here for parts and prices . Hopefully I will be up and running soon. I don't have a tail-stock yet so can't tell how straight the poor girl is. smile o
                            #448770
                            larry phelan 1
                              @larryphelan1
                              Dave, Tell me about parts and prices !!!
                              You are welcome anytime and good luck with your rebuild.
                              PS Don't worry about the rust I,ve seen worse much worse !wink
                              #448806
                              Gerard O’Toole
                                @gerardotoole60348
                                In much the same position as yourself, I have a small lathe for making items for my motorcycle too. Situated in Galway so I too am familiar with both the cost and scarcity of machines and tools
                                Best of luck with the A10, what year?
                                #448810
                                steamdave
                                  @steamdave
                                  Welcome, Dave and hello from West Cork.
                                  You might consider joining the Myford Owners .io group to get helpful advice with your machine.
                                  https://groups.io/g/myfordlathes
                                  The Emerald Isle
                                  #448827
                                  Harry Wilkes
                                    @harrywilkes58467
                                    Welcome to the forum got a bit of work on yours hands there, look forward to end result
                                    H
                                    #448888
                                    Daithi
                                      @daithi
                                      Larry, Yup, there's hope for the girl. Thanks again yes
                                      Gerard, When I say A10 in reality its a box of bits which the missus can understand my attraction to. I'm planning to build a Super Rocket replica with alternator and Norton primary. Won't make the rivet counters happy thought. What are you riding yourself?
                                      Steamdave, Thanks for the link. I had great plans for this evening but I will chalk it down to "research" and no doubt will wander back over later for another look.
                                      Harry, Its not as if I don't have enough to do around here. Suppose it's keeping out of the pub beer
                                      #448896
                                      Former Member
                                        @formermember19781
                                        #448914
                                        Daithi
                                          @daithi
                                          Thanks Bill. Always lusted for a Triton but only managed to drop a T120 into an Bizza frame, Went like the clappers all the same smile d
                                          0)
