Hi Tony,
I assume you are cutting constant depth bevels. In practice it's not critical, but if you can arrange it so that all the cuts start from the small end of the gear (and have this facing outwards for visibility, if mounted on a stub mandrel in a chuck).
This is because all three (or both if you are brave) cuts pass through the same point at the small end and it should be easy to judge if the cutter is too high or low when you do the 'blank rol'l and reset the cutter, simply by offering the stationary cutter up to the small end.
