Best way to cut mild steel sheets
Home Forums Beginners questions Best way to cut mild steel sheets
  • This topic has 22 replies, 14 voices, and was last updated 26 May 2022 at 19:14 by Richard Millington.
Viewing 23 posts - 1 through 23 (of 23 total)
  • #11213
    Y C Lui
      @yclui16187
      Y C Lui
        @yclui16187
        The sheet is 2 mm thick. SAE-AISI 1018 cold roll. I need to cut out a plate taking the shape of several arcs combined so end mills is the only tool option for me. I have tried 2-flute 5 mm end mill which is OK but the amount of materials removed seems to be more than necessary. If I go for smaller diameter end mills, chip evacuation will be a problem. Will roughing end mills be better ? 4 flutes or 2 ( haven't seen such type ) ? what diameter and RPM will be optimum ?
        #599256
        Paul Lousick
          @paullousick59116
          I rough cut 2mm steel sheet with a thin blade in an angle grinder first then clean up on the mill.
          #599257
          Thor 🇳🇴
            @thor
            I would use a 2-flute cutter (slot drill), have you tried a 4mm? Might save a bit more material. I have usually farmed out such jobs to a Milling, Turning & Welding shop near me.
            Thor
            #599259
              You won't find much in the way of roughing cutters below 6mm and even if you found a 4mm one by the time you have left some material for a clean up cut with a standard cutter you will be removing almost as much as the 5mm.
              4mm 3-flute carbide cutter would do, 5000rpm if you can, say 300mm/min feed. Blow chips away with compressed air or rig up a vacuum cleaner.
              #599262
              Y C Lui
                @yclui16187
                Posted by JasonB on 26/05/2022 07:31:57:
                That is the cutting process I have been dreaming about but 5000rpm and 300mm/min feed is way outside the envelope of my 300 lb bench mill ( Emco FB2 )
                It appears that even with appropriate cutter and machine it is still not possible to do a full-depth cut of 2 mm in one go as three passes were done in the video ( DOC was 0.7 mm in each pass ). Is that because of chip evacuation problems ?
                I have got the idea of using roughing end mills because my 6 mm roughing end mill cuts slots ( DOC 3 mm ) in mild steel with significantly less effort compared with my regular mill of the same diameter. Furthermore, the chips produced are smaller which should help to avoid clogging.
                Edited By Y C Lui on 26/05/2022 08:20:00
                #599265
                jann west
                  @jannwest71382
                  seems like there's more ways to cut sheet steel than with a end mill … Plasma cutter, water jet, laser … google suggests that there are metal nibblers available from amazon that will do 2mm sheet steel.
                  #599268
                  Hopper
                    @hopper
                    Depends how big it is and how complex the shape is. But you could mark it out and cut it with a hacksaw, bandsaw, angle grinder etc then file it to final shape.
                    #599269
                    John Haine
                      @johnhaine32865
                      Model Engineers Laser
                      #599270
                      Dave Halford
                        @davehalford22513
                        Supermarket Plasma cutter, leaves a 1mm cut line. Use a wooden template to guide the torch if like me you don't have a CNC equipped mill and an old metal biscuit tin underneath to catch the dross.
                        #599272
                        Nick Wheeler
                          @nickwheeler
                          curved cuts in 2mm steel would be a jigsaw job for me, as they're difficult to do with an angle grinder. Plasma cutter is good too.
                          You didn't say what they are for, which dictates the finish required.
                          #599276
                            Posted by Y C Lui on 26/05/2022 06:26:20:
                            Why ask what the optimum RPM will be when you don't have a mill capable of running at the optimum speed, What do the makers of your cutters suggest? Most have charts that give a good starting point.
                            #599279
                            Ady1
                              @ady1
                              That's why I got a plasma cutter from Lidl, while groaning "Not ANOTHER 150 quid fer gawd sake!"
                              But they cut up to 12mm of steel in any direction you want more easily and quickly than anything us home shop people have ever been capable of before
                              #599284
                              Nick Clarke 3
                                @nickclarke3
                                Posted by Ady1 on 26/05/2022 09:49:35:
                                +1
                                Nick
                                #599286
                                Paul Lousick
                                  @paullousick59116
                                  Lots of good suggestions for cutting the 2mm plate,. 5000 rpm mill, laser cutter, plasma cutter, etc, BUT how many model engineers with a basic home workshop have these tools or can afford to pay to have it done ? . I don't which is why I would rough cut it with an angle grinder and finish it on the mill.
                                  Edited By Paul Lousick on 26/05/2022 10:34:19
                                  #599290
                                  Y C Lui
                                    @yclui16187
                                    Posted by Paul Lousick on 26/05/2022 10:33:44:
                                    The fact is I don't even have an angle grinder because all the stuffs I made are rather small. The workpiece in the question is just 45 mm long / wide. I have tried dremel-like tool + cut-off wheels but the wheels break quite easily. Will seriously consider getting an angle grinder. Looks like a must-have.
                                    #599293
                                    Hopper
                                      @hopper
                                      Posted by Y C Lui on 26/05/2022 10:44:41:
                                      The fact is …The workpiece in the question is just 45 mm long / wide.
                                      Mini hacksaw and file. Easy peasy.
                                      #599294
                                      jann west
                                        @jannwest71382
                                        "The workpiece in the question is just 45 mm long / wide."
                                        DingDingDing we have a winner – for the single most essential piece of information, which took 15 comments before it was disclosed.
                                        See Hopper's answer – mini hacksaw and file.
                                        #599296
                                        Martin Kyte
                                          @martinkyte99762
                                          Bandsaw or Jigsaw.
                                          regards Martin
                                          #599298
                                          Dave Halford
                                            @davehalford22513
                                            Posted by Nick Clarke 3 on 26/05/2022 10:10:19:
                                            +1
                                            Nick
                                            I got the £80 one laugh
                                            #599299
                                            Nick Wheeler
                                              @nickwheeler
                                              Posted by Hopper on 26/05/2022 10:50:57:
                                              And takes about the same time as reading this thread
                                              #599305
                                              Nigel Graham 2
                                                @nigelgraham2
                                                I often resort to a hacksaw, so offer this tip:
                                                Clamp the sheet flat on a suitable surface so you cut the steel at an angle, bringing more teeth to bear on the cut and reducing or preventing horrible vibration and noise.
                                                #599410
                                                Richard Millington
                                                  @richardmillington63972
                                                  Jigsaw.
