Best Material for Draincock-Linkage
Home Forums Workshop Techniques Best Material for Draincock-Linkage
  • #263566
    Johannes Grabsch
      @johannesgrabsch91508
      Hallo
      Over time the linkages to the draincock valves of my locos become sloppy, as the holes in the links at the joint become larger or oval. There is normally not enough 'flesh' to uses bushes, so I am looking for alternatives. Is there a better material than mild steel? Or what other options are there?
      Thanks
      Johannes
      Johannes Grabsch
        #263702
        julian atkins
          @julianatkins58923
          I suggest something else is amiss. None of my locos have shown the slightest wear in the drain cock linkeage over in some cases 20 -30 years.
          Cheers,
          Julian
          #263903
          Johannes Grabsch
            Hallo
            I may not be clear enough. This is what I ment
            Johannes
            #263904
              Posted by Johannes Grabsch on 31/10/2016 06:52:15:
              Hallo
              Johannes
              surprise … That's remarkably clear evidence !!
              I would note Julian's wise words … Surely there must be something wrong [bad geometry, or excessive friction] elsewhere.
