Benjamin Franklin
Benjamin Franklin
Home Forums Clocks and Scientific Instruments Benjamin Franklin
  • #61754
    David Costello
      @davidcostello75947
      Any
      David Costello
        @davidcostello75947
        Any comments?
        #61755
        John Stevenson 1
          @johnstevenson1
          Benjamin Franklin
          Any comments?
          OK I’ll make one, second picture is out of focus.
          John S.
          #61759
          1
            @1
            Errrr…yes.
            Not being a horologist, forgive my ignorance, but what am I looking at?
            #61761
            ady
              @ady
              What time is it?
              It’s a kind of spiral clock with 4 hours per revolution…
              :-0
              I will guess at 1:40
              Edited By ady on 04/01/2011 20:57:54
              #61763
              David Costello
                @davidcostello75947
                Well i thought you were clock men—what your looking at is a one handed wall clock weight driven,with pendulum,apparently designed by Benjamin Franklin late 18c,you may notice attached to the minute hand is a pointed finger which retracts into the spherical to denote the hour,these clocks are sometimes described as three wheel type.I was hoping for further information,sorry about picture quality its my first attempt.
                David Costello
                  @davidcostello75947
                  Well done Ady spot on.
                  Sub Mandrel
                    @submandrel
                    But how does the hand reset after 12 hours?
                    Seems a lot of complexity to add to make up for losing the minute hand!
                    David Costello
                      @davidcostello75947
                      Hi Neil
                      Sorry,only just seen your question,upon reaching 12 the pointed hour finger ie the brass one just continous in the same circ;le to 1 o,clock,no reset required,its a bit tricky to describe,but i am sure you get the idea.If you would like the drawings to make there is a book “Clockmaking For The Model Engineer” Thorne,Camden used to stock it.
                      Dave.
