Thanks Jason and pgk, the lever just turns a cam that holds off the governor. I will be replacing the coil with a CDI unit when I strip it down, the ignition's a bit optional as the plug sits quite deep in the head and the spark isn't particularly strong.
Apologies for the poor quality video, it's the first time I've used the camera for about two years and I probably should have cleaned the lens first.
So the question is, what next? I don't have a milling machine (yet) so I'm a little restricted on what I attempt. I suppose I should revisit my failed Laura stirling engine before starting anything else.
Andy
Edited By Andrew Holdaway on 26/04/2016 17:37:04
