Bending steel tube
Bending steel tube
Home Forums Beginners questions Bending steel tube
  • #4955
    Mike Hibbins 1
      @mikehibbins1
      Mike Hibbins 1
        @mikehibbins1
        I need to bend some 16mm X 1mm wall steel tube to make an
        exhaust for a model aircraft.
        I’ve looked at commercial benders but can’t find anything 16mm.
        Has anyone got any ideas??
        Edited By David Clark 1 on 22/02/2010 15:00:18
        #48357
        Alan Worland 1
          @alanworland1
          Hi Mike,
          I have bent smaller steel tube by filling it with copper wires
          from cable – it seemed to work quite well.
          Used also to be done in the old days by filling with sand
          Alan
          Edited By David Clark 1 on 22/02/2010 15:00:38
          #48361
          mgj
            @mgj
            I have one idea- use ali instead. Used to do a lot of tuned
            pipe headers in ali – softer than steel, and with these
            ali-weld kits, pretty easy to join. If you are going to use ali,
            make sure its not heat treated to 1/2 hard. If you want to
             use steel, anneal. (Why steel – isn’t weight a problem?)
            However the basic procedure is tolerably simple.
            Make a “blank” in soft wire first as a gauge.
            Plug one end with solder or epoxy. Fill with sand.
            Plug the other end and bend over formers.
            Ideally the former wants to have a groove at least 50% of the
            pipe dia in it to stop wall collapse.
            Unwise, I’m told to use copper by the way.
            Something in my mind says copper and ali pistons don’t
            go too well, but maybe that is only in petrol engines.
            Edited By David Clark 1 on 22/02/2010 15:05:46
            #48369
            Gordon W
              @gordonw
              I use lead as a filler if at all pos., sand is messy, and if heat
              is needed must be very dry.
              Cheap plumbers benders with ally formers are made for std.
              15mm o/d pipe and are easy to file out  to 16mm if required.
              For one offs formers from wood are OK.
              Copper exausts make a nice noise, and should be easy to
              keep away from the piston.
              Edited By David Clark 1 on 22/02/2010 15:06:31
              #48370
              Peter Gain
                @petergain89847
                Try using “Wood’s metal”. It has a very low temp melting
                point of 100c.
                Use as for lead, plug one end, fill with Wood’s & bend.
                Easy to melt out.
                Available from Alec Tiranti.
                I have not checked to see how competitive they are price wise.
                Edited By David Clark 1 on 22/02/2010 15:06:56
                #48372
                mgj
                  @mgj
                  Copper – yes it does make a nice noise, but its not the copper
                  in contact with the ali – its the products of combustion, copper
                  and ali. Get a lot of pitting on the top of the piston crown etc,
                  as I recall, but quite willing to be corrected..
                  May not apply to engines running on methanol.
                  I agree – sand is messy, but a 16mm tube full of solid lead or
                  woods metal is going to take a bit of force bending?
                  All you have to do is drill a small hole in each plug to let the
                  steam out (if any). Best to dry your sand in the oven in a tray – or
                  one of those big sweet tins. ( Or a few holes in the end bits you
                  are going to saw off.) At least with sand you can just pour it in,
                  without worrying about molten lead, so one might define messy
                  as relative?
                  16mm, if you anneal or normalise it’ll bend cold with the right
                  former. Might be worth choosing the right grade of steel at that.
                  Cold Drawn Seamless is not going to help anything!
                  Edited By David Clark 1 on 22/02/2010 15:09:16
                  #48374
                  D.C.Clark
                    @d-c-clark
                    Fill the pipe with water.  Freeze it, bend it, thaw it.
                    Lower melting temperature than lead or Cerro alloys, safer
                     and easier to work with, much cheaper.
                    This time of year, in most of the Northern Hemisphere, you
                    don’t even need a freezer.
                    David Clark in Southern Maryland, USA
                    Edited By David Clark 1 on 22/02/2010 15:08:56
                    #48375
                      You can get 16mm conduit benders,
                      may even be able to hire one for a day.
                      Jason
                      Edited By David Clark 1 on 22/02/2010 15:14:14
                      #48380
                      Tony Martyr
                        @tonymartyr14488
                        I spent a happy year of my apprenticeship bending steel
                        and nickel-copper-iron tube into complex shapes and fitting
                        them to Admiralty turbines. For steel tubes we always used
                        fine dry sand thus – wooden plug in the tube and pour in
                        sand, tapped the tube over its full length, pour in more sand
                        and repeat until the level drops no more then drive in top
                        wooden plug – heat the tube in the area of the bend and pull
                        into shape when bright red. Now the fun bit; cut off the ‘spare
                        end’ complete with plug and pour sand into dry container then
                        heat the other end just before the pug until red hot then turn off
                        oxygen and blow acetylene up the tube until it explodes and
                        blows the plug out as a smoking projectile far down the
                        pipe-shop – highly satisfying!
                        I feel obliged to say = ‘Don’t try this at home’
                        For exotic (seawater resistant) and thin walled pipes we always
                        used lead which was much hotter work and far less fun.
                        Tony
                        Edited By David Clark 1 on 22/02/2010 15:10:12
                        #48384
                        MichaelR
                          @michaelr
                          You could maybe get a suitable sized bending spring to fit
                          the tube, and give that a try, used with a simple wood former
                          it may do the job.
                          Edited By David Clark 1 on 22/02/2010 15:10:47
                          #48401
                          Ian S C
                            @iansc
                            Mike,what radius is the bend?
                            #48405
                            Mike Hibbins 1
                              @mikehibbins1
                              Thanks for all the advice.
                              To answer one or two questions:-
                              The weight of steel over aluminium is not a problem, with a
                              70cc twin turning a 23in prop a few grams won’t make any
                              difference.
                              I’m not totally sure of the radius yet, I haven’t finished the
                              design of the silencer. I guess somewhere around 80mm.
                              I’m going to start experimenting with some of the techniques
                              suggested, I’ll let you know how I get on.
                              Edited By David Clark 1 on 22/02/2010 15:11:12
                              #48410
                              Circlip
                                @circlip
                                At that radius, you can almst bend it over your knee.
                                Seriously, by using a grooved wooden former and a grooved
                                wiper roller you could probably bend it in a vise.
                                 Used a “Cheap” conduit bender to form a Stainless airline
                                system without kinks.
                                  Regards  Ian.
                                Edited By David Clark 1 on 22/02/2010 15:11:39
                                #48453
                                Ian S C
                                  @iansc
                                  I used 16mm steel tube(its proberbly 1.5MM), when I built
                                  a trailer for my bike,it had the the bends built in.I use an
                                  old tubular folding chair,saved a lot of work,and looks good.
                                  Ian S C
                                  Edited By David Clark 1 on 22/02/2010 15:12:06
                                  #48617
                                  Eastleighite
                                    @eastleighite
                                    Use a plumbers bender with a 22mm former.
                                    Cut 6in. pieces of 22mm copper tube in half – ‘lengthwise’,
                                    (enough to pack out the former and slide) .
                                    Anneal the steel tube. in way of bend,  insert 15mm. bending
                                    spring and away you go.
                                    Edited By David Clark 1 on 22/02/2010 15:39:23
