Posted by Vincent Cutajar on 08/03/2011 17:41:26:
I spent all the morning experimenting with scrap mild steel of roughly the same dimension. Using an oxy-propane torch I could not get it hot enough in the vice as it was dissipating most of the heat. After I ran out of scrap steel I gave up and went home.
In the afternoon I had a nice 'siesta' and when I woke up I had an idea which I had to try.
Went back to the garage, Fixed a milling vice (with smooth jaws) to the milling table, clamped the metal I wanted to bend, inserted a 6 foot metal water pipe to use it as a lever and pushed the pipe. And 'viola' the steel rail bent nicely. It took me less than 10 minutes to do. Can't imagine why I did not think of this method before.
Thanks all for your input
Vince
That is one of the worst stories I have heard about cruelty to machines, it must have been a big machine bolted to the floor to resist the force you applied via a 6' lever too.
I presume the milling machine and vice was someone else's property!
I don't understand what you mean with 'ran out of scrap steel', or how it is connected to the part you are bending.
Ian P
