Keith
Assuming your gauge plate is ANSI O1 tool steel its much stronger than the aforementioned ones.
Around twice as strong as 817M40 so it should be much stiffer in a small section. Unfortunately I don’t have a handy quick reference but a quick look round the internet suggests :-
Tensile Strength 140 tons / sq inch minimum
Yield Strength 130 tons / sq inch
Elongation % 5 % minimum
It’s not clear from the source I found what the heat treatment / temper state is for those figure but from the context I infer that the figures apply to the working hardness of around 60 HRC.
Please remember that although I’m a retired scientist / R&D Engineer I’m not a metallurgy guy. I just have some decent references.
For this sort of thing I like the data given by John Bradley in his book “The Racing Motorcycle, a guide for constructors” Volume 2 which covers materials as he has real practical experience of serious engineering using the Home Shop level resources where your choice of materials is seriously constrained by what you can actually get. If you are building your own racing motorcycle it’s advisable to ensure that it doesn’t fall apart and dump you on the road at umpteen MPH. I’ve met John and he absolutely knows what he is talking about.
Frankly given the effort involved in making the valve gear parts I’d get gauge plate and be sure the material is up to the job. Although the published designers at our level may not have done full blown engineering calculations they will have pretty shrewd idea st to what in practice works. As ever the general rule is :-
“If its stiff enough its strong enough”
Given the small sections involved in many model parts getting enough stiffness can be tricky.
I’m Home Shop guy working in 12″ to the foot scale so no practical experience.
