Well, the way i am working in my head about this lathe purchase,
it's replacing a CJ18 mini lathe with a 100mm chuck, and MT3 spindle bore.
So really any bigger lathe will be better here, i need more rigidity, must have power cross feed, and it must be metric,
i have no way to machine the ways of a lathe, i haven't got a clue about scraping, and no mill to make up new gib strips etc, so really buying a 50 year old english lathe is out of the question.
As much as i'd love to get the chester craftsman, to get the even bigger spindle bore etc, it's 400 kilo weight means i'd have to cut holes in the shed floor and pour concrete pads, so that will be a purchase to make in 10 years time when i might… no 'will' have a concrete floored workshop and my own house.
In my wooden shed/workshop that i built last year, I built a workbench for the mini lathe, it's 450mm deep, 1150mm wide, and 1003mm tall.
So i'm going to have to make a bigger bench if i get the Warco which is 620mm deep, and if the change gear / belt door is hinged like on the WM250, that'll make things even harder to accommodate.
The WM280's length is 1350mm, but the tailstock can overhang onto the other bench like i do with the mini lathe now :
I've read that the warco chip pan does not sit direct on a bench, it needs chunk of ply under it to raise the centre a bit, so if i got some 18 or ideally 25mm ply, that'd hopefully help where i'd have the headstock and tailstock on different bench tops, the lathe will be bolted through the benches.
That shelf above the mini lathe will have to go too
as the warco is 500mm tall, but the splash guard on both the warco and the chester is extra deep to allow a milling head to be bolted onto the back, here the older size splashguard that couldn't accommodate the mill head would be handier for me, wonder if i can get the lathe with an old style splash guard, or i could just chop the new one up, but don't want to do that with a brand new machine… hence why i really wanted to buy second hand, but no one seems to be selling one atm.
Now,
If i went for the chester lathe, i'd just remove the bench and put it on it's included stand in the space the bench was… but then i loose all that storage below which currently holds 4 large boxes of materials, bottles of oils and so on, but some of that can go in the 2 cupboards of the chester stand, and i can add extra shelves between them, even make an emergency stop bar that goes across them at the base n that.
Really my choices are Warco WM280V, or Chester DB10VS,
The toolco 1130GV version of these lathes is never in stock (TBH nothing is ever in stock on that site, been looking at mills for the past year) and emails asking when one would be in and it's price go unanswered, shame as that lathe has a 38mm spindle bore.
And the Amadeal AMA280VFF wont be in stock for 3 – 4 months
But the chester has the crappy DC motor drive the same as the mini lathe, and only 250 watts more than my current motor!!
Ok it's 500 quid cheaper than the warco, and i guess to retro fit an AC 3 phase motor and VFD would not even cost that much (about £60 for a 1.5kw inverter, and £150 for the motor it seems)
But doing that mod will bugger the warranty up i guess… yet again, if i could get one of these second hand that'd be my best option.
I could ask chester about this, but i've been emailing them asking about buying a DB10S lathe, as well a asking which vertical slide fits it, But after the first 2 replies when i asked about a discount (no) i am getting no more replies, … wonder if chester are still on here? …
I keep reading about the storage containers chester have full of machines they have taken parts off to sell to people who needed warranty replacements, wonder if they have a motorless DB10S in there i could buy?
The only other feature the warco boasts that the chester doesn't is the overload clutch on the fed shaft, now that is something someone like me would need, i guess it's a shear pin on the chester? wonder if that could be retrofitted too.
Chester even do a 500mm bed version of the DB10, that would slot in my shed just perfectly.
