Bench mill problem
Bench mill problem
Home Forums Electronics in the Workshop Bench mill problem
  • #570434
    Phillip Priestley 2
      @phillippriestley2
      Hi, hopefully someone can help with this baffling ( to me) problem. I have a Chinese vertical mill BMD 45 with a 6 speed geared head, it starts and runs in ok in five of the six gears but upon trying to start it in sixth gear the spindle can only manage about 100 rpm. I have read that capacitors can be problematic but why on only one speed if that is what it is?
      Thanks in anticipation
      Phillip
      #32220
      Phillip Priestley 2
        @phillippriestley2
        Motor will not run up to speed in top gear
        #570435
        Clive Foster
          @clivefoster55965
          Phillip
          A single phase motor cannot intrinsically self start because it is stable stationary when power is applied so not turning torque is to get it moving is produce.
          The starter winding, and capacitor if its that sort of motor, are electrically offset relative to the main winding so an unbalanced torque is developed to get the motor going. Once its running fast enough the motor can continue accelerating on its own so the starter winding (and capacitor) are switched out.
          The amount of offset torque depends on the winding configuration an capacitor size. If there isn't enough offset torque to overcome the load the motor will be unable to accelerate up to speed so will try and run at the fastest speed it can reach. A failing capacitor has less capacitance than it should so starting and run up torque is also lower.
          Higher gear ratios impose more starting loads on the motor so when a capacitor begins to fail the effects on starting will be noticed first in the highest speed gear.
          Exactly your symptoms which is why capacitor problems are the common suggestions for things not working.
          #570437
          Dave Halford
            @davehalford22513
            If you run it first in 4th gear for five minutes and then start it in 6th is it better?
            If it's OK like that, the oil just needs to warm up.
            #570461
            Bountyboy
              @bountyboy
              Hi,
              I had a similar problem with my EMCO mill and that also needed a new capacitor.
              To quote Kiwi Bloke who helped me…….
              "Just in case you don't know, make sure you get a 'motor run' capacitor, not a 'motor start' capacitor. The latter are electrolytic and will fail after very little running time. The former are usually metallised polypropylene. They are cheap, and available from electric motor suppliers, re-winders, electrical wholesalers, RS Components, Farnell (now called Element 14 – I think), etc."
              I wasn't aware of this and I managed to get one from RS Components.
              Hope this is of use smiley
              #570482
              Phillip Priestley 2
                @phillippriestley2
                Hi, Thanks for the replies, I took the easy option and ran it in fourth gear for ten minutes, naturally it started straight away in top gear, then I left it a while and it would only start after I ran it in fourth again. I have just been back to remove the capacitor covers to obtain the details on them, replaced the covers and lo and behold it started first time in top gear! I am now off to sit in a darkened room for a bit!!
                Thanks
                Phillip
                #570484
                Phillip Priestley 2
                  @phillippriestley2
                  Just as an afterthought I have two capacitors on the motor, one 30 if 450v ac
                  the other one is 130 if 250 v ac which is start and which is run?
                  Thanks
                  Phillip
                  #570485
                  Phillip Priestley 2
                    @phillippriestley2
                    Sorry the above should read uf and not if
                    #570533
                      Posted by Phillip Priestley 1 on 08/11/2021 20:27:35:
                      Thanks
                      Phillip
                      I always recommend getting a copy of Tubal Cain's 'Model Engineer's Handbook', which covers electric motors and much else. The book shows many variations but the low value capacitor (in uF) is usually the Run capacitor.
                      I'd change both capacitors: the poor things take a beating and don't last forever. If one has failed, the other is likely to be on the way out too. Sourcing them is easy because single-phase motors are common as muck and their capacitors often fail. The capacitors are of particular construction for this service so make sure the product description includes the words 'START' and 'RUN'. Most electronic component and motor spares places sell them, example link to CPC/Farnell, .
                      I'm suspicious your 130uF capacitor is only rated at 250VAC: I'd rate both of them at 450V. Can one of the experts comment please?
                      John Haine
                        @johnhaine32865
                        Interestingly CPC only list "run" caps and only up to 80uF. RS do list them but only available through affiliated suppliers. CPC list 30, 70, and 80uF, you could always replace the 130 with a 70 and 80 in parallel.
                        #570553
                        mgnbuk
                          @mgnbuk
                          Capacitor supplier
                          Not used them, but came across them when looking for a replacement induction motor fan. They also do start capacitors.
                          Nigel B.
                          #570555
                          not done it yet
                            @notdoneityet
                            Changing both capacitors (an 80 & 50 for the 130 plus the other one) could be getting close to the realms of changing the motor for a 3 phase one (second hand?) and buying in a VFD to drive it. Almost certain to solve the problem along with lots of programmable options.
                            that larger capacitor may well have been swapped in by a previous owner? Something he had, tried and it ‘worked’?
                            Edited By not done it yet on 09/11/2021 11:32:32
                            #570559
                            Dave Halford
                              @davehalford22513
                              Run caps are in the 400V range
                              Start caps are 250V
                              The construction is different.
                              #570560
                              Dave Halford
                                @davehalford22513
                                Posted by Phillip Priestley 1 on 08/11/2021 20:19:14:
                                Thanks
                                Phillip
                                Did you move the wiring, twist the caps round to read them etc. If so just check the wiring isn't bad.
                                #570563
                                Phillip Priestley 2
                                  @phillippriestley2
                                  Yes I had to twist them round to obtain the details from them, it now starts every time, I think I should be sourcing a new pair of capacitors for my peace of mind. To answer another question I bought it new, so the capacitors are the ones it left China with!
                                  Thanks
                                  Phillip
                                  #570564
                                  Dave Halford
                                    @davehalford22513
                                    Posted by Phillip Priestley 1 on 09/11/2021 12:22:49:
                                    Thanks
                                    Phillip
                                    By 'check the wiring isn't bad' I mean check the wires aren't loose in the spade connector crimp, that bare wire is actually touching the spade connector (and hopefully welded to it) and that the spade terminals are not loose on the cap body.
                                    #570574
                                    Roger Best
                                      @rogerbest89007
                                      Moved wires now it works sounds like a bad connection.
                                      New bits won't hurt, if you can avoid electrolytic capacitors, they dissolve themselves after 8 or 10 years, and anything they dribble acid onto.
