Posted by richard markham on 08/12/2019 10:09:03:
Posted by Lainchy on 07/12/2019 20:20:37:
One thing I have noticed is that most people use collets on the lathe, especially for small shafts, rods etc. I only have a big old 3 jaw and 4 jaw. A set of Burnerd Collets is pricey. Are collets essential or is there a slightly cheaper way to go? The CNC has an ER20 collet chuck, so maybe I can find an adaptor for the M300 to take ER20 or go to an ER32.
Not sure most people use collets on the lathe, though they can be very useful I don't use mine much.
If the work can be turned in one go, three jaw chucks are quick and easy to use. But, it's difficult to reset work in them with any accuracy, for example when you start a job in the lathe, move to a mill or vice, and then return to finish off on the lathe. With a 3-jaw, it's highly unlikely the second axis will align with the first.
Four jaw chucks are slower to set up but, ideally with a DTI, can be adjusted to restore the original axis. Bit fiddly, takes practice, and slow. But not a problem unless speed is of the essence.
Collets allow work to be moved between machines with speed and accuracy. For general use they have a few disadvantages: cost of chuck and individual collets, limited range grip range per collet means many have to be bought, and they aren't handy for jobs involving several different diameters.
My guess is most of us use three and four jaw chucks most of time because they're well-suited to most work. Apart from being resettable, collets are also good for delicate accurate work like clock making because the absence of jaws means the cutter and operator can get much closer to the job, and run-out is much reduced. For general purpose work, chucks have the edge.
Your big old 3- and 4-jaw may need to be complemented with smaller newer chucks if they're too big to grip the items you want to turn. Chucks would be more use to me than collets.
