Yes, sometimes BMS will distort when you stress relieve it, like cutting out the space for the axle boxes. I used 1/8" BMS, and it did not distort. Although, I did make sure that the material was as flat as possible before cutting. Also, to a certain degree, the frame spacers and front and rear beams will keep the frames straight. Make sure everything is perfectly square when you clamp and drill for the screws that hold everything together.
