Beginner’s Clock Questions
Home Forums Clocks and Scientific Instruments Beginner’s Clock Questions
  • #213675
    James Alford
      @jamesalford67616
      For some years now, I have toyed with building a clock. Now that I have a lathe (Flexispeed), I have decided to have a go. I have a couple of other projects to complete first, so have time to get prepared.
      I have seen several plans for wooden clocks, such as these two:
      http://www.woodenclocks.co.uk/clock11.html
      http://www.woodenclocks.co.uk/clock24-gravity-3.html
      but the wheels are too large for the Flexispeed to manage.
      I have a couple of questions: is it possible to simply scale down the size of the gears, leaving the swing of the pendulum as it is, or will this cause problems?
      Alternatively,can anyone suggest an interesting looking, but relatively simple weight-driven clock suitable for a beginner with a small lathe?
      Thank you.
      JAmes.
      James Alford
        @jamesalford67616
        #213687
        John Haine
          @johnhaine32865
          Gear size is unrelated to pendulum swing generally, except for the escapement wheel. However in wood it would get increasingly difficult to make smaller gears. I suggest you look at John Wilding designs, he has a design for a weight driven egg timer which is supposed to be easy to build as a starter.
          #213688
          James Alford
            @jamesalford67616
            John,
            Thank you for your reply.
            I forgot to say in my original post that I do want to build the clock in metal, not in wood.
            JAmes.
