Beginners 31/2″ loco
Home Forums Locomotives Beginners 31/2″ loco
  • #53390
    Eddie Price 1
      @eddieprice1
      I have built a couple of 16mm locos and would now like to try something a bit bigger. I am not a skilled machinist, but I get by with a mini lathe and mini mill. I looked through the Reeves catalogue of 31/2″ locos and found Juliet and Tich. The Juliet plans are £30 and the Tich plans are £65. Does this mean that Juliet may be more difficult to build with fewer sheets?
      Any thoughts on a beginners engine? and also a supplier of castings, laser cut parts? Reeves tend to be a bit pricy.
      Eddie Price
      Eddie Price 1
        @eddieprice1
        #53398
        Nigel Hyde
          @nigelhyde97004
          Hi Eddie
          I am just finishing off a tich and i have struggled like mad on it (too small as i didnt make it slip eccentric!!)
          I am the same as you as i am not a machinist i am a carpenter, I have tha advantage of my dad who has built 5″ locos and is a very skilled engineer
          If i was starting again i would look at something like a sweet voilet (3.5″)or sweet pea(5″)
          mainly using blackgates
          tich is ok as an engine but i have spent 4 years on it and at my club the track is fairly big and me being on the festively plump side and my daughter whats a ride on it !!
          for a bit more work you might get a more usefull engine
          sweet violet plans from blackgates are £20 and oinly 4 sheets
          simple as hackworth valve gear and a marine boiler
          but above all build something YOU want to build
          (i have no conections with blackgates)
          hope this helps
          Nigel
          #53408
          Eddie Price 1
            @eddieprice1
            Hi Nigel
            Thanks for your comments. It confirms what I had picked up from comments on forums over the years that Tich is quite difficult for the beginner  I hadn’t heard of Blackgate. I had a look at their web site and they have some interesting plans.
            My nearest SME Club is Hereford so I may pay them a visit at one of their open-days and see if any of their members are into 3 1/2″. I think the boiler would be the biggest challenge. I managed it for the 16mm, but they are tiny. It would be nice to have someone on hand (like a club member) who could offer advice and help.
            Will do some more research
            Eddie
            #53410
            David Haynes
              @davidhaynes53962
              Hi Eddie,
              There is a lot of discussion either way on Tich.  A recent set of postings at another forum gives a journey towards a good little engine, but some wil still find it too much work for the results that many receive.  Have a look at http://modeleng.proboards.com/index.cgi under “Tich”, and “Thanks NASA”
              There are a lot of unfinished locos around and it seems to me that an unfair amount are of this little one, which is a shame really.
              Good luck and all the best
              Eddie Price 1
                @eddieprice1
                Thanks David.
                Obviously some people are happy with Tich. I hope to be able to have a chat with some of the Hereford club members and see if I can get some first hand experience and views.
                Eddie
                #53465
                David Haynes
                  @davidhaynes53962
                  Hi Eddie,
                  That’s quite okay.  An early experience I had in asking for a club comment was being told “if you want my opinion, you will scrap all the work that has been done so far and pick a proper loco”. This was from a 7 1/4″ enthusiast.  Other later comments have been much more supportive, but I have been put off discussing any difficulties in that forum.  That said, there are well documented difficulties and any mistakes are only expensive in respect of your time and not your pocket.  I made mistakes on driving wheels but was able to get a new set for much less than if it had been a bigger loco.
                Home Forums Locomotives Topics
