Hi all,
Thanks for the replies.
The irony of it is, the plans had it as a vertical engine with the flywheel at the bottom, I decided to build it as a horizontal but the engine has decided it is a vertical with the flywheel at the top !
Brian – I think part of the problem is the Kelly kettle has a small surface area of water at the top, it also needs to be reasonably full so I get a lot of water entering the tubing in relation to the steam generated. It's far from ideal as a boiler.
Ian – it does run better when it's hot but still struggles when horizontal, it may even improve on its own after it's been run in a bit
Peter.
