I was taught at secondary school to use 4-figure logs to base 10 which I found quite fascinating. I was never taught to use anti-logs, so worked it out for myself, then asked the maths teacher who effectively said,if it works for you, do it.
Slide rules, of which I still have three, were the province of Technical College maths. All three have the A, B, C & D scales which make square roots dead easy, but only the 5" Helix A50S has the K scale for cubes & cube roots. Simple means, simple devices, relatively coarse in precision, yet sufficiently good enough for most, if not all, practical purposes. The only problems are the requirement to be able to work out the multiples of 10 required (sorry, forgotten the correct term here), and the difficulty in learning how to use them.
As far as square roots are concerned, there is a method, which I've now forgotten, whereby they could be calculated using the old, original 4 function plus K constant calculator. I seem to think that the method could be done longhand. Plus, I have a recollection that an expansion to the key sequencing could be used to produce cube roots.
Ah, happy memories.
Peter G. Shaw
