Posted by Ady1 on 24/12/2022 18:15:57:
The beep bit used to be on the motherboard and could be set and heard during the boot sequence
If your board doesn't beep during the boot sequence then that's a starting point
i.e. the startup beep may be switched off
the beeps were used for highlighting boot up errors, 2,3,4,etc told you where a problem was
autoexec.bat
config.sys
(omg…about a million years ago now)
Edited By Ady1 on 24/12/2022 18:23:21
It might be before that, and need accessing the BIOS; different hardware has different commands, but it might come up on screen during POST (Power On Self Test) F2 was certainly used, as was F9 and DEL, though confusingly some of the same Function buttons were also used for safe boot on different machines.
This of course assumes the beeper is actually fitted, so mk1 eyeball for that.
Try accessing the BIOS and see if Beeps are turned off.
Bill
