bearings
bearings
Home Forums Materials bearings
  • #29819
    mick70
      @mick70
      mick70
        @mick70
        is there a good site where i can input od-id and width of bearings to get bearing i need?
        need to find some for project.
        want to see if i can put some different bearings in a bike hub to fit 14mm axles into it.
        Edited By mick70 on 10/06/2018 15:46:54
        #357118
        Thor 🇳🇴
          @thor
          Hi Mick,
          Something like this you were looking for?
          Thor
          #357119
          mick70
            @mick70
            that's great cheers
            #357145
            geoff walker 1
              @geoffwalker1
              Mick,
              simply bearings have a great range of bearings, may have what you need.
              https://simplybearings.co.uk/shop/
              geoff
              #357330
              Howard Lewis
                @howardlewis46836
                Take a look at the first pages of the Arc Euro catalogue.
                That lists the bearings that they stock and sell, giving ID/OD/Width and the code says whether open, shielded or rubber sealed. The first page covers Metric, (from 1 x 3 x 1 to 35 x 72 x 17 ) over the page are the Imperial sizes, (0.0551 x 3/16 x 7/64 to 1 x 2 x 1/2 ). Then there are the Angular Contact ones, and Taper Roller, Needle Roller, and Drawn Cup varieties, as well as Ball and Needle Thrust Bearings. So you may find what you are looking for there.
                Despatch is quoted as "Within two working days" but they often arrive next day in UK.
              Home Forums Materials Topics
